[gdal-dev] gdaltindex produces absolute paths
Even Rouault even.rouault at spatialys.com
Fri Feb 20 09:04:51 PST 2015
Le vendredi 20 février 2015 16:36:34, Pedro Venâncio a écrit :
> Hi,
> Some time ago I opened this bug report (http://hub.qgis.org/issues/11428),
> because I thought it was a problem of the implementation of gdaltindex in
> QGIS, but now I see that it isn't, because it also happens at the command
> line.
> If I put the command line in the folder where the raster files are located
> [0], gdaltindex works well, ie, with -write_absolute_path option, absolute
> paths are saved in the attribute table, and without -write_absolute_path
> option are saved only the names of files.
> But if I reference the input raster files with the absolute paths [1] (for
> example, when files are in different folders), the -write_absolute_path
> option has no influence, because absolute paths are always recorded in the
> attribute table.
> This is the desired behavior, or is it a bug?
Pedro,
per the usage message of gdaltindex:
"" o Raster filenames will be put in the file exactly as they are specified"
  on the commandline unless the option -write_absolute_path is used.""""
so this is at least the documented behaviour :-)
In your case, you would rather need a "-write_relative_path" that would
compute the relative path of the referenced paths with respect to the tile
index location (which can be something that could not succeed for example if
the files are on different drives on Windows)
Even
http://www.spatialys.com
