[gdal-dev] Problems with GDAL 1.10.1 converting from NetCDF to Geotiff
VictoriaH bhudspeth at edac.unm.edu
Tue Jan 6 07:10:50 PST 2015
Hello,
I am running GDAL 1.10.1 on an Ubuntu 14.04 machine. When I try to create a
Geotiff from a NetCDF file, I get the following error. The problem does not
occur when using an earlier version of GDAL (e.g. 1.9.2). I have seen some
discussion of this issue on the mailing lists, but it is unclear what the
workaround is. I would appreciate any information about how to get around
this issue.
ERROR 1: nBlockYSize = 663, only 1 supported when reading bottom-up dataset
ERROR 1: NETCDF:PM25_2004_06_average.nc:Data, band 1: IReadBlock failed at X
offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
I use the following as an example:
gdal_translate -ot Byte -of GTiff NETCDF:"PM25_2004_06_average.nc":Data
pm_2004.tif
Thanks for any help...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-GDAL-1-10-1-converting-from-NetCDF-to-Geotiff-tp5180197.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
