[gdal-dev] OGR: How to access Coded Value Domains in File Geodatabases?
Stefan Keller sfkeller at gmail.com
Tue Jan 6 17:20:27 PST 2015
ArcGIS offers "Coded Value Domains" (short: "coded domain") to specify
a valid set of values (code+description) for an attribute [1].
Any clues on how to access this information using ogr2ogr, i.e. how to
export this to a separate table when converting e.g. from a ESRI File
Geodatabase (OpenFileGDB, .gdb directories) to Spatialite or
GeoPackage?
Yours, S.
[1] http://resources.arcgis.com/en/help/main/10.1/index.html#//001s00000001000000
