[gdal-dev] how to set filegdb encoding
Even Rouault even.rouault at spatialys.com
Wed Jan 7 00:47:18 PST 2015
Le mercredi 07 janvier 2015 09:41:35, wxx a écrit :
> the dirver of shp file  in ogr can support chinese character by setting
> CPLSetConfigOption("SHAPE_ENCODING","");
> how to set encoding about filegdb dirver to support chinese character.
> now all the chinese character in the attribute field is messy code.
The FileGDB driver (as most drivers) expects attribute values to be passed in
UTF-8 encoding (and this is the encoding used in the FileGDB binary format
itself), so you'll likely have to convert on your side from your chinese
encoding into UTF-8.
Even
http://www.spatialys.com
