[gdal-dev] why the layer changed geometry type after insert into gdb
Rebecca wxx114 at 163.com
Wed Jan 7 02:35:14 PST 2015
I created a gdb with filegdab api  in gdal, then create an ogrlayer int gdb
by function CreateLayer(newlayername,spatial,geotype,option),
 the thrid parameter "geotype"=wkbLinestring, after created the layer,  I
get the layer geometry type by function layerGeoType=pLayer->getgeomtype();
but the "layerGeoType"=wkbmultilinestring, is not the same as before I set
the layer type wkbLinestring.
  I tried wkblinestring layer, wkbpolygon layer , all the layer into gdbfile
, their geometry type become wkbmultilinestring, wkbmultipolygon, how could
I control the layer geometry type in filegdb which would be the same as
before.
Rebecca
View this message in context: http://osgeo-org.1560.x6.nabble.com/why-the-layer-changed-geometry-type-after-insert-into-gdb-tp5180310.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
