[gdal-dev] OGR can't create PCIDSK polygon file
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Thu Jan 8 04:22:47 PST 2015
liminlu0314 <liminlu0314 <at> 163.com> writes:
> OGR cannot create the PCIDSK polygon vector data, Found in the GDAL library
> code is not achieved, I realize part of the code, surface vector data can
> create PCIDSK type.
> The modified code is as follows
I believe that the developers would like if you could make a ticket to
http://trac.osgeo.org/gdal/.
Patches seem to often a title beginning as [PATCH]... and the patch itself
contains the changes parts (diff). An example:
http://trac.osgeo.org/gdal/ticket/5504
I also feel that a new autotest case to be added to
http://trac.osgeo.org/gdal/browser/trunk/autotest/gdrivers/pcidsk.py would
be appreciated.
That way your work will have better chances to be applied to the code base.
-Jukka Rahkonen-
