[gdal-dev] Cropping a raster by a polygon - only nodata outside polygon wanted
Even Rouault even.rouault at spatialys.com
Wed Jan 14 02:39:21 PST 2015
Mathieu,
If 0 is a valid value at some locations of your raster, then you cannot use it
as the nodata value. Use an alpha band instead for example by using -dstalpha
instead of -dstnodata 0
Even
> Hello,
> I crop a 3 band raster by a polygon with the following formula :
> /gdalwarp -of GTiff -cutline polygon.shp -cl polygon input.tif output.tif
> But pixels outside my polygon are assigned the 0 value. I'd like them to
> have nodata
> If I put the -dstnodata 0 option :
> -dstnodata 0/, all the pixels in each of the 3 bands that contain the 0
> value will be turned to nodata, even if they are contained in my polygon.
> Hence, 127 0 222 will become 127 nodata 222
> or 0 127 222 will become nodata 127 222
> How to put the nodata value only outside my polygon ?
> Thanks a lot in advance !
> Mathieu
http://osgeo-org.1560.x6.nabble.com/Cropping-a-raster-by-a-polygon-only-nodata-outside-polygon-wanted-tp5181426.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
