[gdal-dev] loading ESRI File Geodatabase into POSTGIS
Even Rouault even.rouault at spatialys.com
Fri Jan 16 02:07:29 PST 2015
Zoltan,
I believe File Geodatabase support, either through FileGDB or OpenFileGDB
driver, should be rather solid in GDAL 1.11.1. There are some bugs in the
FileGDB SDK based driver (for example it cannot handle some "exotic" SRS), but
OpenFileGDB has not those limitations.
Regarding topology support, I'm not sure if File Geodatabase has support for it,
but both OGR drivers wouldn't handle that. They support feature tables only. But
if your data is proposed in both vector, I'd assume it is only feature tables.
So I don't think there's really an advantage in selecting one of the formats,
especially if you intend to ingest it into PostGIS just after.
Even
> Hi,
> I've been offered some vector data in either Shapefile format, or File
> Geodatabase format.
> I'll have to pay for the extract time, so I want to choose correctly.
>  1. How reliable is the new File Geodatabase reader in gdal 1.11.1?
>  2. Is there any benefit (in terms of information, topology, anything?)
>     to getting file Geodatabase instead of Shape format?
>     (I've read the famous "9 Reasons" doc, so I'm aware of the obvious
>     limitations like field names, null values etc - I'm thinking more
>     like "does Geodatabase have any topology - like adjoining polygons
>     share the common line)
> The data will be networks (sewer, water etc) and polygons - I'd kind of
> prefer to use Geodatabase as I have an inherent dislike to Shape files
> and their limitations, but not if there are still issues with the gdal
> geodatabase reader.
> I intend to put the received data into postgis.
> Anyone care to share some experiences?
> Regards & thanks,
> Zoltan
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax:    +27-86-6115323     www.geograph.co.za
http://www.spatialys.com
