[gdal-dev] Compiling gdal 1.11.1 on ubuntu 14.10
Homme Zwaagstra hrz at geodata.soton.ac.uk
Fri Jan 16 02:20:32 PST 2015
On 16/01/15 07:45, Zoltan Szecsei wrote:
> Hi,
 > I compiled QGIS 2.7 successfully on ubuntu 14.10, and then noticed
that it had gdal 1.10, so I downloaded the source for gdal 1.11.1 and
compiled it.
 > The trouble is that running gdalinfo --version still gives me the
1.10 version.
 > Can anyone spot my deliberate error?
Have you tried running the ldconfig command after running `make install` on
GDAL?  This should solve the dynamic link issues resulting in the
version errors
you're experiencing when running the GDAL 1.11.1 binaries.
Alternatively you can adjust the `LD_LIBRARY_PATH` environment variable
to point
to `/usr/local/lib` e.g.
     LD_LIBARY_PATH=/usr/local/lib /usr/local/bin/gdalinfo --version
You should also compile any dependent software after installing your
custom GDAL
i.e. compile GDAL first then QGIS.
Best regards,
Homme
 > This is a new system for experimenting with, so I am able to nuke it
and start again by reloading ubuntu if need be.
 > My goal is to fiddle with QGIS dev, python dev, mapserver and postgis.
 > I'd like GRASS and  OTB  as well, plus all the "normal" dependencies
like gdal, ogr, proj.....
 > (So if someone has a recipe for the correct installation sequence so
that all the dependencies work out with their correct versions, please
post it on this list.)
 > Thanks & regards,
 > Zoltan
 > So, to the current status:
 >     #before make install:
 >     geograph at gs01:~$ which gdalinfo
 >     /usr/bin/gdalinfo
 >     #after make install:   (note the different location)
 >     # So howcome?:
 >     geograph at gs01:~$ /usr/bin/gdalinfo --version
 >     GDAL 1.10.1, released 2013/08/26
 >     geograph at gs01:~$
 >     geograph at gs01:~$ /usr/local/bin/gdalinfo --version
 >     geograph at gs01:~$
 > Just before sending this email I did:
 >     which gdalbuildvrt
 >     /usr/local/bin/gdalbuildvrt
 >     gdalbuildvrt --version
 >     ERROR 1: gdalbuildvrt was compiled against GDAL 1.11.1 but
current library version is 1.10
 > I then got into synaptic and removed gdal-bin and python-gdal but not
libgdal-dev and libgdal1h (all ver 1.10) as the last one would have
removed grass and a bunch of other stuff, including postgre 9.4 and
postgis, which I want.
 > The above is after running sudo make install:
 >     geograph at gs01:~/dev/cpp/gdal-1.11.1$ sudo make install
 >     [sudo] password for geograph:
 >     (cd port; make)
 >     make[1]: Entering directory '/home/geograph/dev/cpp/gdal-1.11.1/port'
 >     make[1]: Nothing to be done for 'default'.
 >     make[1]: Leaving directory '/home/geograph/dev/cpp/gdal-1.11.1/port'
 >     (cd gcore; make)
'/home/geograph/dev/cpp/gdal-1.11.1/gcore'
 >     make[1]: Leaving directory '/home/geograph/dev/cpp/gdal-1.11.1/gcore'
 >     (cd alg; make)
 >     make[1]: Entering directory '/home/geograph/dev/cpp/gdal-1.11.1/alg'
 > etc etc etc (and then the last few lines of the make install follow):
 >     libtool: install: /home/geograph/dev/cpp/gdal-1.11.1/install-sh
-c .libs/ogrtindex /usr/local/bin/ogrtindex
-c .libs/ogrlineref /usr/local/bin/ogrlineref
-c .libs/testepsg /usr/local/bin/testepsg
-c .libs/gdalbuildvrt /usr/local/bin/gdalbuildvrt
 >     /bin/bash /home/geograph/dev/cpp/gdal-1.11.1/libtool
--mode=install  /home/geograph/dev/cpp/gdal-1.11.1/install-sh -c
gdal-config-inst /usr/local/bin/gdal-config
-c gdal-config-inst /usr/local/bin/gdal-config
 >     make[1]: Leaving directory '/home/geograph/dev/cpp/gdal-1.11.1/apps'
 >     for f in LICENSE.TXT data/*.* ; do
/home/geograph/dev/cpp/gdal-1.11.1/install-sh -c -m 0644 $f
/usr/local/share/gdal ; done
--mode=finish --silent /usr/local/lib
 >     /home/geograph/dev/cpp/gdal-1.11.1/install-sh -d
/usr/local/lib/pkgconfig
 >     /home/geograph/dev/cpp/gdal-1.11.1/install-sh -c -m 0644 gdal.pc
/usr/local/lib/pkgconfig/gdal.pc
 >     geograph at gs01:~/dev/cpp/gdal-1.11.1$ which gdalinfo
 >     geograph at gs01:~/dev/cpp/gdal-1.11.1$ gdalinfo  --version
 > Zoltan Szecsei PrGISc [PGP0031]
 > Geograph (Pty) Ltd.
 > GIS and Photogrammetric Services
 > P.O. Box 7, Muizenberg 7950, South Africa.
 > Mobile: +27-83-6004028
 > Fax:    +27-86-6115323     www.geograph.co.za
 > gdal-dev mailing list
 > gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150116/b173a8b3/attachment-0001.html>
