[gdal-dev] Closed polyline from DXF as line or area?
Andre Joost andre+joost at nurfuerspam.de
Mon Jan 26 07:25:04 PST 2015
Am 26.01.2015 um 15:29 schrieb Even Rouault:
> It seems the documentation matches the initial implementation but has been
> outdated by later changes. Indeed, ogr/ogrsf_frmts/dxf/ogrdxflayer.cpp contains
> the following (disabled) code :
The behaviour might have changed with the implementation of is ticket:
https://trac.osgeo.org/gdal/ticket/4680
but noone thought of adjusting the dxf driver manpage.
BTW: creating polygons from closed lines is still not available in GDAL
or other osgeo command line tools?
<http://osgeo-org.1560.x6.nabble.com/gdal-dev-MULTILINESTRING-to-MULTIPOLYGON-using-ogr2ogr-td5018430.html>
was the latest I could find.
Greetings,
André Joost
