[gdal-dev] Closed polyline from DXF as line or area?
Even Rouault even.rouault at spatialys.com
Mon Jan 26 09:19:54 PST 2015
Le lundi 26 janvier 2015 18:12:30, Andre Joost a écrit :
> Am 26.01.2015 um 16:36 schrieb Even Rouault:
> > Le lundi 26 janvier 2015 16:25:04, Andre Joost a écrit :
> >> BTW: creating polygons from closed lines is still not available in GDAL
> >> or other osgeo command line tools?
> >> <http://osgeo-org.1560.x6.nabble.com/gdal-dev-MULTILINESTRING-to-MULTIPO
> >> LYG ON-using-ogr2ogr-td5018430.html> was the latest I could find.
> > André,
> > Looks like it works now with trunk. Probably a side effect of my recent
> > work on curve geometries where I significantly enhanced conversions
> > between geometry types
> Thanks, works perfectly.
> So +1 from me for a quick relase of 1.11.2 (to get it into the next QGIS
> version as well).
This will not be in 1.11.2 but in GDAL 2.0
> Greetings,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
