[gdal-dev] Call for discusson on RFC 52 Strict OGR SQL quoting
Dmitriy Baryshnikov bishop.dev at gmail.com
Mon Jan 26 13:01:31 PST 2015
I just check PostGIS. Create a table with name test.test in test schema.
The result looks so:
CREATE TABLE test."test.test"
   id serial NOT NULL
Also, if schema name have spaces it'll be look like: "test
test"."test.test".
And what about other DBs?
Best regards,
     Dmitry
26.01.2015 23:49, Jukka Rahkonen пишет:
> Even Rouault <even.rouault <at> spatialys.com> writes:
>> Hi,
>> This is a call for discussion on the new "RFC 52 - Strict OGR SQL quoting",
>> based on an older ticket.
>> http://trac.osgeo.org/gdal/wiki/rfc52_strict_sql_quoting
>> Summary :
>> This RFC proposes that OGR SQL enforces strict quoting rules for SQL literals
>> and identifiers.
> Hi,
> Could there be a need to think about the "schema"."table" structure? I have
> some memories about (silly) users having table names with dots like
> "MY.TABLE". If I remember right, with some database the SQL query
> SELECT "field" FROM "MY.TABLE"
> was being interpreted wrongly as "select field named 'field' from table
> named 'table' from schema named 'my'".
> I do not really know if this trouble belongs to GDAL at all but I share my
> weigh memories anyhow.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
