[gdal-dev] Python3 continuous testing
Even Rouault even.rouault at spatialys.com
Tue Jan 27 05:56:45 PST 2015
Le mardi 27 janvier 2015 14:49:01, Tamas Szekeres a écrit :
> Hi Even,
> I've noticed build issue on Windows using the latest (stable) Python3.x
> versions, hope that this fix will solve that problem too.
Hi Tamas,
Thas would be surprising since my commits solved runtime failure, not build
failure. Which error do you get ?
I don't see any error when looking at :
http://build.gisinternals.com/sdk/build-output/vc10-20150127-6-56-46-62-vc10-
dev.txt
> Thanks,
> Tamas
> 2015-01-27 13:44 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> > Hi,
> > Just to notify you that I've added a python3 branch for Travis-CI testing
> > : https://travis-ci.org/rouault/gdal_coverage/branches
> > Before today's commits, Python 3 bindings had been broken in trunk for a
> > few
> > months without anyone noticying/complaining. Now this should no longer
> > happen.
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
