[gdal-dev] Quick question about gdal2tiles
Jorge Arévalo jorge at cartodb.com
Wed Jan 28 15:05:32 PST 2015
> Even Rouault <mailto:even.rouault at spatialys.com>
> January 28, 2015 at 9:28 PM
> Le mercredi 28 janvier 2015 20:17:08, Jorge Arévalo a écrit :
>> Hi,
>> I'm working with a patched version of gdal2tiles, which makes use of
>> parallelization:
>> http://gis.stackexchange.com/questions/7743/performance-of-google-map-tile-
>> creation-processes/74446#74446
>> I want to create a complete TMS cache from raster imagery. No
>> assumptions about SRS of data type for input data.
>> I want the tiling process to be as fast as possible (gdal2tiles is
>> really heavy process), do you have any recomendations about the data or
>> the parameters used?
>> Right now, I'm doing this
>> Step 1: build vrt from input images
>> gdal_vrtmerge.py -o merged.vrt<list of input tif files>
>> Step 2: build tiles from vrt file
>> gdal2tiles.py -r cubic -s epsg:XXXX -z 0-19 -w all merged.vrt tms_dir
>> Even with parallelization, process still feels really slow. Would it be
>> faster if, for example, I convert all my input files to epsg:3857? Or if
>> I scale them to 8-bit? Or if I use near resampling method instead of
>> cubic? (I'm using cubic because I'm working with continuous data:
>> satellite images, am I doing it right?).
>  From a quick look at the source, it seems that there's an optimization if the
> input SRS == output SRS that avoids going through the warped VRT path.
> That said, we definitely need one or several maintainers for gdal2tiles. There
> are quite a faw patches floating around in Trac that would need someone to
> review, test, fix, apply them, as well as writing tests (no autotest for
> gdal2tiles yet), etc...
Ok. But the applications is taking hours to generate a complete tile
cache (zoom levels 0-19) for a 3MB tiff file, in epsg:3857. A 4 cores
machine with 8GB of RAM. The file is this one
https://dl.dropboxusercontent.com/u/6599273/gis_data/katrina-3857.tif
Taking so much time for a 3MB file sounds ridiculous. I'm probably doing
something wrong. This is the line
gdal2tiles.py  -s epsg:3857 -z 0-19 -r cubic katrina-3857.tif tiles_dir
Do you see something wrong in this approach?
Anyway, if this is a problem of gdal2tiles and it needs fine tunning or
maintenance, we could talk. I don't know if there's any other method to
generate a complete TMS cache using GDAL.
>> Any other tips?
>> Many thanks in advance
>> Best regards
Sent with Postbox <http://www.getpostbox.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150129/aba5bc28/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150129/aba5bc28/attachment.jpg>
