[gdal-dev] ​Re: Raster origin coodinates in file header
Adrien ANDRÉ adr.andre at laposte.net
Thu Jul 2 01:12:47 PDT 2015
Even, Piero,
thank you very much for your detailed answers !
Adrien
Le 30/06/2015 08:41, Piero Campalani a écrit :
> Adrien,
> OGC in its GML standard document -- of course in line with ISO --
> recommends that:/
> "When a grid point is used to represent a sample space (e.g. image
> pixel), the grid point represents the center of the sample space (see
> ISO 19123:2005, 8.2.2)"/. ​
> ​GML encodes the locations of a raster/gridded-coverage by means of a
> grid of ​0D points.
> ​You can always put your raster origin wherever you want, i.e. in
> whatever corner you prefer.
> Alas, there's no way -- that I am aware of -- to specify what is the
> shape of a measurement footprint/sample-space, nor to say if the
> footprint surrounds the point-geometry equally (point is pixel-centre)
> or some other way (point is pixel-upper-left-corner?).
> Hence raster creators should probably stick to this recommended encoding
> until standards do not offer more freedom on this :)
> ​@seeAlso
>http://rasdaman.org/wiki/PetascopeSubsets
> http://rasdaman.org/ticket/680​
> ​Piero !​
> On 29 June 2015 at 21:00, <gdal-dev-request at lists.osgeo.org
> <mailto:gdal-dev-request at lists.osgeo.org>> wrote:
>     Date: Mon, 29 Jun 2015 11:12:11 +0200
>     From: Adrien ANDR? <adr.andre at laposte.net
>     <mailto:adr.andre at laposte.net>>
>     To: gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     Subject: [gdal-dev] Raster origin coodinates in file header
>     Message-ID: <55910BEB.2030307 at laposte.net
>     <mailto:55910BEB.2030307 at laposte.net>>
>     Content-Type: text/plain; charset=utf-8; format=flowed
>     Dear list,
>     opening 2 rasters with different resolutions i noticed a shift.
>     Asking our imagery provider, i was told the origin coordinates they
>     store in image header (JP2 files) are those of the top left pixel
>     center.
>     GDAL reads origin coordinates as the top left pixel top left corner
>     coordinates, as i'm used to.
>     Of course, i fixed my problem, the hacky way, playing with
>     gdal_translate a_ullr option, but:
>     How to deal with this?
>     How not to worry about georeferencing each time i load a raster file?
>     Is there any OGC recommendation about origin coordinates storage?
>     Thanking you in advance,
>     Regards,
>     Adrien
> gdal-dev mailing list
