[gdal-dev] Merge all features in polygon shapefile with gdal
Luke lukepinnerau at gmail.com
Mon Jul 6 22:03:49 PDT 2015
Steven,
Remove the group by and it will ignore the attributes.
    ogr2ogr output.shp input.shp -dialect sqlite -sql "SELECT
ST_Union(geometry) FROM input"
Regards
Luke
Steven Lutz wrote
> this is what I've come up with:
> "SELECT ST_Union(geometry), dissolve_field FROM input GROUP BY
> dissolve_field"|
> it looks to me that it is trying to do this operation based on specific
> attribute entries but I'm looking to ignore the attribute entrie and
> make all features into one.
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Merge-all-features-in-polygon-shapefile-with-gdal-tp5214520p5214533.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
