[gdal-dev] Attempting to access an ArcGIS REST API through a WMS format minidriver
Passmore, James H. jpass at bgs.ac.uk
Tue Jul 7 08:42:07 PDT 2015
>From http://www.gdal.org/frmt_wms.html  I see you can access an ArcGIS REST API like:
gdalinfo "http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer?f=json&pretty=true"
and
gdal_translate "http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer?f=json" wms.xml -of WMS
These above examples work for me.
When I try on a BGS service it fails as below:
...:\>gdalinfo "https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=true"
gdalinfo failed - unable to open 'https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=
true'.
And:
..:\>gdal_translate "https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=true" bgs.xml -of WMS --debug ON
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_BAG.dll using GDALRegister_BAG.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_FITS.dll using GDALRegister_FITS.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_GMT.dll using GDALRegister_GMT.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF4.dll using GDALRegister_HDF4.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF4Image.dll using GDALRegister_HDF4Image.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF5.dll using GDALRegister_HDF5.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF5Image.dll using GDALRegister_HDF5Image.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_KEA.dll using GDALRegister_KEA.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_MG4Lidar.dll using GDALRegister_MG4Lidar.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_MrSID.dll using GDALRegister_MrSID.
GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_netCDF.dll using GDALRegister_netCDF.
HTTP: Fetch(https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=true)
WMS: Did not get levels
GDALOpen failed - 0
Is the reason that HTTPS is not supported here at all, or if not what might be wrong with the service/request/ configuration?
Thanks
James
 This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
