[gdal-dev] Attempting to access an ArcGIS REST API through a WMS format minidriver
Dmitry Baryshnikov bishop.dev at gmail.com
Wed Jul 8 04:51:47 PDT 2015
Hi James,
As the server didn't provide information about levels, some help needed
to calculate this values. Also the all layers switched off, so we need
to tell which layers should be shown.
I create such xml file based on information from here:
https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=true
  <GDAL_WMS>
     <Service name="AGS">
<ServerUrl>https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer</ServerUrl>
         <ImageFormat>png</ImageFormat>
         <Layers>show:1,2,3</Layers>
         <BBoxOrder>xyXY</BBoxOrder>
         <SRS>3857</SRS>
     </Service>
     <DataWindow>
         <UpperLeftX>-1821098.1612395868</UpperLeftX>
         <UpperLeftY>9441422.428028269</UpperLeftY>
         <LowerRightX>1157719.0542395862</LowerRightX>
         <LowerRightY>6462605.212549096</LowerRightY>
         <SizeX>1024</SizeX>
         <SizeY>1024</SizeY>
     </DataWindow>
</GDAL_WMS>
$ gdal_translate -of PNG ~/tmp/ags.xml ~/tmp/ags_test.png --config
CPL_DEBUG ON
GDAL: GDALOpen(/home/bishop/tmp/ags.xml, this=0x15138c0) succeeds as WMS.
Input file size is 512, 512
AGS: URL =
https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer/export?f=image&bbox=-1821098.16123959,6462605.21254910,1157719.05423959,9441422.42802827&size=512,512&dpi=&imageSR=3857&bboxSR=3857&format=png&layerdefs=&layers=show:1,2,3&transparent=false&time=&layerTimeOptions=&dynamicLayers=
HTTP: Requesting [1/1]
HTTP: Request [0]
: status = 200, content type = image/png, error = (null)
GDAL: GDALOpen(/vsimem/wms/0x15dc720/wmsresult.dat, this=0x15c3d00)
succeeds as PNG.
GDAL: GDALClose(/vsimem/wms/0x15dc720/wmsresult.dat, this=0x15c3d00)
0...10...20...30...40...50...60...70...80...90...100 - done.
GDAL: GDALClose(/home/bishop/tmp/ags_test.png, this=0x1599830)
GDAL: GDALClose(/home/bishop/tmp/ags.xml, this=0x15138c0)
Also I test this xml in QGIS - works fine.
Best regards,
     Dmitry
07.07.2015 18:42, Passmore, James H. пишет:
> >Fromhttp://www.gdal.org/frmt_wms.html   I see you can access an ArcGIS REST API like:
> gdalinfo"http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer?f=json&pretty=true"
> and
> gdal_translate"http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer?f=json"  wms.xml -of WMS
> These above examples work for me.
> When I try on a BGS service it fails as below:
> ...:\>gdalinfo"https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=true"
> gdalinfo failed - unable to open 'https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=
> true'.
> And:
> ..:\>gdal_translate"https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=true"  bgs.xml -of WMS --debug ON
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_BAG.dll using GDALRegister_BAG.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_ECW_JP2ECW.dll using GDALRegister_ECW_JP2ECW.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_FITS.dll using GDALRegister_FITS.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_GMT.dll using GDALRegister_GMT.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF4.dll using GDALRegister_HDF4.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF4Image.dll using GDALRegister_HDF4Image.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF5.dll using GDALRegister_HDF5.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_HDF5Image.dll using GDALRegister_HDF5Image.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_KEA.dll using GDALRegister_KEA.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_MG4Lidar.dll using GDALRegister_MG4Lidar.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_MrSID.dll using GDALRegister_MrSID.
> GDAL: Auto register C:\apps\gisinternals\bin\gdaL\plugins\gdal_netCDF.dll using GDALRegister_netCDF.
> HTTP: Fetch(https://map.bgs.ac.uk/arcgis/rest/services/UKSO/UKSO_BGS/MapServer?f=json&pretty=true)
> WMS: Did not get levels
> GDALOpen failed - 0
> Is the reason that HTTPS is not supported here at all, or if not what might be wrong with the service/request/ configuration?
> Thanks
> James
> ________________________________
>   This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150708/c429e09b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150708/c429e09b/attachment-0001.png>
