[gdal-dev] gdal_translated converted kml doesn't cover whole earth
Pan, Jianfu (GSFC-423.0)[COLUMBUS TECHNOLOGIES AND SERVICES INC] jianfu.pan at nasa.gov
Thu Jul 23 05:23:22 PDT 2015
I have a geotif file that covers a region from 85S to 80N and 180W to 180E. I was able to read out the lat/lon values in the tif and they cover from 83.632S to 83.632N and 179.813W to  179.813E. When I translate the tif to kml, it shows up on Google Earth from 180W to 179.01E (not all the way to 180E), leaving a gap.  Can anyone help?
Here is the listgeo output from the tif:
Geotiff_Information:
   Version: 1
   Key_Revision: 1.0
   Tagged_Information:
      ModelTiepointTag (2,3):
         0                 0                 0
         -17367530.4451649 7314540.64739566  0
      ModelPixelScaleTag (1,3):
         36032.2208405911  36032.2199379096  0
      End_Of_Tags.
   Keyed_Information:
      GTModelTypeGeoKey (Short,1): ModelTypeProjected
      GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
      GTCitationGeoKey (Ascii,31): "Cylindrical Equal Area (WGS84)"
      GeographicTypeGeoKey (Short,1): GCS_WGS_84
      GeogGeodeticDatumGeoKey (Short,1): DatumE_WGS84
      GeogLinearUnitsGeoKey (Short,1): Linear_Meter
      GeogAngularUnitsGeoKey (Short,1): Angular_Degree
      GeogEllipsoidGeoKey (Short,1): Ellipse_WGS_84
      GeogSemiMajorAxisGeoKey (Double,1): 6378137
      GeogSemiMinorAxisGeoKey (Double,1): 6356752.31424
      ProjectedCSTypeGeoKey (Short,1): User-Defined
      ProjectionGeoKey (Short,1): User-Defined
      ProjCoordTransGeoKey (Short,1): CT_CylindricalEqualArea
      ProjLinearUnitsGeoKey (Short,1): Linear_Meter
      ProjLinearUnitSizeGeoKey (Double,1): 1
      ProjStdParallel1GeoKey (Double,1): 30
      End_Of_Keys.
   End_Of_Geotiff.
Projection Method: CT_CylindricalEqualArea
   ProjStdParallel1GeoKey: 30.000000 ( 30d 0' 0.00"N)
   ProjNatOriginLongGeoKey: 0.000000 (  0d 0' 0.00"E)
   ProjFalseEastingGeoKey: 0.000000 m
   ProjFalseNorthingGeoKey: 0.000000 m
GCS: 4326/WGS 84
Datum: 6030/(unknown)
Ellipsoid: 7030/WGS 84 (6378137.00,6356752.31)
Prime Meridian: 8901/Greenwich (0.000000/  0d 0' 0.00"E)
Projection Linear Units: 9001/metre (1.000000m)
Corner Coordinates:
Upper Left    (-17367530.445, 7314540.647)  (179d60' 0.00"E, 85d 2'40.38"N)
Lower Left    (-17367530.445,-7314540.647)  (179d60' 0.00"E, 85d 2'40.38"S)
Upper Right   (17367530.445, 7314540.647)  (179d60' 0.00"W, 85d 2'40.38"N)
Lower Right   (17367530.445,-7314540.647)  (179d60' 0.00"W, 85d 2'40.38"S)
Center        (       0.000,       0.000)  (  0d 0' 0.00"E,  0d 0' 0.00"N)
Thank you.
Jianfu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150723/f6297192/attachment.html>
