[gdal-dev] using gdal_merge with floating images
Even Rouault even.rouault at spatialys.com
Mon Jul 27 10:37:02 PDT 2015
On Sunday 26 July 2015 00:40:48 Andrea Peri wrote:
> Hi,
> I'm try-ing to merging some rasters using gdal_merge.
> The raster are all float64 and with differents interval of values.
> Is this kind of rasters compatible with gdal_merge ?
> I ask because , my try was stopped with a crash.
gdal_merge should be able to work with any data type as far as I can see. It
could have issues with rasters that don't fit into RAM, but this should result
in a "clean" error, not a process termination.
You can try with gdalwarp as well
> And perhaps this could be the explanation.
> Many thx.
http://www.spatialys.com
