[gdal-dev] GDAL Landsat Dirver
Dmitry Baryshnikov bishop.dev at gmail.com
Mon Jun 1 06:26:17 PDT 2015
I would like to note that the Landsat metadata files support added to
GDAL 2.0
(https://svn.osgeo.org/gdal/trunk/gdal/gcore/mdreader/reader_landsat.cpp)
I think you can use this metadata reader to parse Landsat metadata file,
or set to the Landsat dataset the imagery metadata in same manner.
Also, I think the tests for new format in autotest
(https://svn.osgeo.org/gdal/trunk/autotest/gdrivers/) folder needed.
And, it seems to me that the use:
         char** papszBandMeta = NULL;
         papszBandMeta = CSLAddString(papszBandMeta, pszFilename);
         pLandsatBand->SetMetadata(papszBandMeta);
         poDS->SetBand( iBand+1, pLandsatBand);
should ended with free papszBandMeta array:
         CSLDestroy(papszBandMeta);
But the new driver look promising!
Best regards,
     Dmitry
01.06.2015 15:55, liminlu0314 пишет:
> landsatdataset.cpp
> <http://osgeo-org.1560.x6.nabble.com/file/n5208440/landsatdataset.cpp>
> landsatdataset.cpp is LANDSAT Driver source code
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-Landsat-Dirver-tp5208438p5208440.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
