[gdal-dev] How to hide the GML in WFS
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Tue Jun 2 00:11:03 PDT 2015
Jeremy Palmer <JPalmer <at> linz.govt.nz> writes:
> How do you hide the gml_id field from a WFS service? I think I'm setting
the correct configuration options,
> but it doesn't seem to work:
> Interestingly if I use the new GDAL 2.0 open options (ie. ogrinfo -oo
GML_EXPOSE_GML_ID=NO -oo
> GML_EXPOSE_FID=NO). I get:
> Warning 6: driver WFS does not support open option GML_EXPOSE_GML_ID
> Warning 6: driver WFS does not support open option GML_EXPOSE_FID
> I'm using GDAL 2.0 beta 2.
> Thanks
> Jeremy
Documentation of the WFS driver and config options
http://www.gdal.org/drv_wfs.html
https://trac.osgeo.org/gdal/wiki/ConfigOptions do not mention that
GML_EXPOSE_GML_ID and GML_EXPOSE_FID are supported. Compare with another
configuration option:
GML_INVERT_AXIS_ORDER_IF_LAT_LONG
GML driver specific. Added in GDAL/OGR 1.8.0. See ​GML driver documentation.
Also impacts WFS driver behaviour.
I think that you are trying to use a non-existing feature. I don't know why
it could not be supported, though. Wait for a confirmation from some
developer and consider making a feature request. For me ogrinfo from the
data I captured from WFS and saved into GML with default parameters looks
indeed confusing:
OGRFeature(lv_editable_points):12
  fid (String) = lv_editable_points.12
  gml_id (String) = editable_points.13
  string (String) = kkk
-Jukka Rahkonen-
