[gdal-dev] Bindings
Tamas Szekeres szekerest at gmail.com
Thu Jun 4 12:12:47 PDT 2015
Hi Ari,
Creating language specific main files would be fine for me. We could also
add the "language specific extensions" at the bottom section (like
gdal_csharp_extend.i) directly into the file.
We should however make sure to update all relevant files if a common change
is done in a language specific file.
Best regards,
Tamas
2015-06-04 16:35 GMT+02:00 Ari Jolma <ari.jolma at gmail.com>:
> Hi,
> I've been trying to find a way to make the common SWIG interface files
> less concerned about languages and the whole system more flexible and
> understandable (which I see a prerequisite for further developments).
> My conclusion seems to be now that it is probably better to make the main
> files, what are now gdal.i, ogr.i etc., language specific and only the
> class files, now ColorTable.i, MajorObject.i, etc., and some other files
> (typedefs.i etc.) common. That way each language could compose the module
> as they like. For example in Perl I would like to get rid of Const, and a
> language could put all classes into one module (gdal) etc.
> This would at least require extracting remaining common material in gdal.i
> and ogr.i into new files.
> I'll test this in my github fork - which I've mentioned a couple of times
> already. But it will probably take some time due to summer etc.
> Any comments on this? This is again just internal reorganization and does
> not affect the APIs.
> Ari
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150604/98cfcfc4/attachment.html>
