[gdal-dev] getting height from Geotiff DEM
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Jun 6 08:37:36 PDT 2015
Sorry,
This was the correct answer but for the wrong user list....
Nicolas Cadieux M.Sc.
Les Entreprises Archéotec inc.
8548, rue Saint-Denis Montréal H2P 2H2
Téléphone: 514.381.5112  Fax: 514.381.4995
www.archeotec.ca
On Jun 6, 2015 10:34, Nicolas Cadieux <nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> There is the " value tool plugin" that you can install.  That will give you the values when you move your mouse across  the raster. For more points, install the "point sampling tool" plugin.
> www.archeotec.ca
> On Jun 6, 2015 4:31 AM, djawahar <jawahar_d at hotmail.com> wrote:
> > Hi,
> >    I have a geotiff dem. How can I get the height information given a pixel
> > coordinate? I tried to get the data using
> > gdErr = poDataset->GetRasterBand(1)->RasterIO(
> > GF_Read, 0, 0, poDataset->GetRasterXSize(), poDataset->GetRasterYSize(),
> > pBits, bmi.Header.biWidth, bmi.Header.biHeight, GDT_Byte,
> > 1, nScanSize);
> > but the data is either 0 or 255.
> > What is the right way to do this?
> > Thanks & regards,
> > D. Jawahar
> > View this message in context: http://osgeo-org.1560.x6.nabble.com/getting-height-from-Geotiff-DEM-tp5209506.html
> > Sent from the GDAL - Dev mailing list archive at Nabble.com.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
