[gdal-dev] Validating a projection
Even Rouault even.rouault at spatialys.com
Mon Jun 8 00:46:37 PDT 2015
Selon Andre Joost <andre+joost at nurfuerspam.de>:
> Am 08.06.2015 um 01:38 schrieb Doug McCorkle:
> > Andre,
> > I have updated the projection information with the recommended names.
> > When I process GeoTIFF files with this projection everything works
> > fine while all of the data is in memory and none of the Datasets in
> > question are written to disk. If I write the data to disk in a
> > GeoTIFF file and then try to reload the data and acquire the EPSG
> > with the AutoIdentifyEPSG method I get the unsupported srs error.
> The code 102039 is not an official EPSG code, but rather invented by
> ESRI.
The GeoTIFF format can only store numerical codes <= 32767.
> That is the reason why some software depending on PROJ/GDAL does
> not AutoIdentify the code number.
AutoIdentifyEPSG(), as documented, only works on very few CRS definitions.
> HTH,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
