[gdal-dev] GDAL/OGR C API, how should I be dealing with 'handles'
Mateusz Loskot mateusz at loskot.net
Mon Jun 8 04:25:03 PDT 2015
On 8 June 2015 at 13:07, jramm <jamessramm at gmail.com> wrote:
> Many C API functions return a typedef which is referred to as a handle. E.g.
> OGRFeatureH OGRLayerH OGRGeometryH
> These seem to occur when the C++ api returns a pointer. I have 3 questions:
> Why doesnt the C API return pointers?
H suffix denotes a handle.
Handles are defined as opaque pointer technique
(http://en.wikipedia.org/wiki/Opaque_pointer#C)
In fact, they are pointers.
> How should I pass these 'handles' around. Should I create pointers to them?
No, pass them around and treat them as C/C++ pointers.
> Do I need to free them?
If you mean free as calling C standard free() function, then no,
You should not invoke free with GDAL/OGR handle.
Typically, there is *Close* or *Destroy* function corresponding to particular
handle type, for example
GDALDatasetH h = GDALOpen(...);
GDALClose(h)
or
GDALColorTableH h = GDALCreateColorTable(...)
GDALDestroyColorTable(h)
You need to check C API reference.
Best regards,
Mateusz  Loskot, http://mateusz.loskot.net
