[gdal-dev] GDALWarp API and paletted images
Thomas Sevaldrud thomas at silentwings.no
Tue Jun 9 03:48:08 PDT 2015
I'm using the GDALWarp api from C++ to reproject and cut various input
images. In general this works very well for my purposes, except that for
paletted images I have to use NearestNeighbour resampling,
I would like to use Bilinear or higher order resampling, and wonder if
there is any way to expand a paletted image to true RGB during the warp
process, so I can use these resampling methods.
Alternatively, is there a way to do this conversion (from code) before the
warp without having to run through the entire image in memory?
- Thomas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150609/677d19ab/attachment.html>
