[gdal-dev] assigning vertical datum to image files
Newcomb, Doug doug_newcomb at fws.gov
Tue Jun 9 07:21:09 PDT 2015
Evan,
I went back and checked.  The .aux.xml sidecar files  with the img files do
not appear to have projection information.
Doug
On Tue, Jun 9, 2015 at 9:32 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Selon "Newcomb, Doug" <doug_newcomb at fws.gov>:
> > Thanks!
> > That should work in this case to build the virtual raster.  I'm still
> > curious about assigning the vertical datum to the rasters.
> Doug,
> I'm a bit surprised that the HFA driver reports a SRS with a VERTCS node
> as a
> child of the PROJCS node. I believe this is an incorrect WKT definition.
> There
> should rather be a COMPD_CS root note with 2 children: a PROJCS node for
> the
> horizontal CRS and a VERTCS node for the vertical CRS. Perhaps this SRS
> string
> is defined in the .aux.xml sidecar files that are apparently present ?
> Regarding your question, there are a few EPSG codes that correspond to
> aCOMPD_CS, for example 6349. Otherwise, GDAL allows to build a custom
> COMPD_CS
> with the syntax EPSG:XXXX+YYYY where XXXX is the EPSG code of the
> horizontal SRS
> and YYYY the EPSG code of the vertical SRS. In your case that should be
> EPSG:6543+5703 I think
> So you can do things like "gdal_translate in.tif out.tif -a_srs
> EPSG:6543+5703"
> If you read back out.tif, you will only get the horizontal SRS by default.
> This
> was for backward compatibility reason I think. But if you specify "--config
> GTIFF_REPORT_COMPD_CS YES" you will get the COMPD_CS.
> Even
> > Doug
> > On Tue, Jun 9, 2015 at 1:48 AM, Hermann Peifer <peifer at gmx.eu> wrote:
> > > About your initial problem:
> > > > but gdalbuildvrt complained, informing me that
> > > > they were not in the same projection.
> > > What about using the below gdalbuildvrt option?
> > > Hermann
> > > -allow_projection_difference:
> > > (starting with GDAL 1.7.0) When this option is specified, the utility
> will
> > > accept to make a VRT even if the input datasets have not the same
> > > projection. Note: this does not mean that they will be reprojected.
> Their
> > > projection will just be ignored.
> > > Source: http://www.gdal.org/gdalbuildvrt.html
> > > On 2015-06-08 21:01, Newcomb, Doug wrote:
> > >> Hi Folks,
> > >> I have a directory of 783 .img format Lidar - based  DEMs in the same
> > >> projection, North Carolina State Plane  Feet (2011) , NAD 83 ,
> NVD88.  I
> > >> was going to use gdalbuildvrt to create a single virtual image for the
> > >> area, but gdalbuildvrt complained, informing me that they were not in
> > >> A couple of quick bash scripts/commands
> > >> for x in *.img; do gdalinfo $x >>img_info.txt;done
> > >> and
> > >> grep PROJCS img_info.txt|sort|uniq -c
> > >> gives me the following:
> > >>      437
> PROJCS["NAD_1983_2011_StatePlane_North_Carolina_FIPS_3200_Ft_US",
> > >>      346
> PROJCS["NAD_1983_StatePlane_North_Carolina_FIPS_3200_Feet_2011",
> > >> gdalinfo gives the following for each type of file ( origin section
> > >> clipped out) :
> > >> Driver: HFA/Erdas Imagine Images (.img)
> > >> Files: D05_37_20878102_20141231.img
> > >>         D05_37_20878102_20141231.img.aux.xml
> > >> Size is 1000, 1000
> > >> Coordinate System is:
> > >>      GEOGCS["GCS_NAD_1983_2011",
> > >>          DATUM["NAD_1983_2011",
> > >>              SPHEROID["GRS_1980",6378137.0,298.257222101]],
> > >>          PRIMEM["Greenwich",0.0],
> > >>          UNIT["Degree",0.017453292519943295]],
> > >>      PROJECTION["Lambert_Conformal_Conic_2SP"],
> > >>      PARAMETER["False_Easting",2000000.0],
> > >>      PARAMETER["False_Northing",0.0],
> > >>      PARAMETER["Central_Meridian",-79.0],
> > >>      PARAMETER["Standard_Parallel_1",34.3333333333333],
> > >>      PARAMETER["Standard_Parallel_2",36.1666666666667],
> > >>      PARAMETER["Latitude_Of_Origin",33.75],
> > >>      UNIT["Foot_US",0.30480060960121924],
> > >>      VERTCS["NAVD_1988_Foot_US",
> > >>          VDATUM["North_American_Vertical_Datum_1988"],
> > >>          PARAMETER["Vertical_Shift",0.0],
> > >>          PARAMETER["Direction",1.0],
> > >>          UNIT["Foot_US",0.3048006096012192]]]
> > >> Files: D05_37_20957301_20141231.img
> > >>         D05_37_20957301_20141231.img.aux.xml
> > >> Size is 1000, 1000
> > >>          UNIT["Degree",0.0174532925199433]],
> > >>      PARAMETER["False_Easting",2000000.002616666],
> > >>      PARAMETER["Standard_Parallel_1",34.33333333333334],
> > >>      PARAMETER["Standard_Parallel_2",36.16666666666666],
> > >> In theory, these should all be EPSG:6543, so just assigning the
> correct
> > >>   horizontal projection/datum with the epsg code should make things
> > >> usable. (i.e,
> > >> gdal_translate -a_"srs epsg:6543" --config GDAL_CACHEMAX 512 -of GTiff
> > >> -co COMPRESS=DEFLATE -co PREDICTOR=3 in.img out.tif )  ( Thank you for
> > >> the EPSG:6543 projection support in GDAL 2.0!)
> > >> However, this only assigns the horizontal infomation, how does one
> > >> assign a vertical datum with a horizontal EPSG code?
> > >> I see the NVD88 code in vertcs.csv , but how would I implement it in
> the
> > >> above command?
> > >> Using gdal 2.0 Beta2
> > >> Doug
> > >> Doug Newcomb
> > >> USFWS
> > >> Raleigh, NC
> > >> 919-856-4520 ext. 14 doug_newcomb at fws.gov <mailto:
> > >> The opinions I express are my own and are not representative of the
> > >> official policy of the U.S.Fish and Wildlife Service or Dept. of the
> > >> Interior.   Life is too short for undocumented, proprietary data
> formats.
> > >> _______________________________________________
> > >> gdal-dev mailing list
> > >> gdal-dev at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Doug Newcomb
> > USFWS
> > Raleigh, NC
> > Interior.   Life is too short for undocumented, proprietary data formats.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Doug Newcomb
USFWS
Raleigh, NC
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150609/285b5af5/attachment-0001.html>
