[gdal-dev] GDALWarp API and paletted images
Thomas Sevaldrud thomas at silentwings.no
Thu Jun 11 08:09:01 PDT 2015
Great, thanks!
I tried this, but got only a red image as result, so I guess only the first
channel was used.
This is the relevant code, where _ds is the input paletted data set
vrtDS = vrtDriver->Create("", origW, origH, 3, GDT_Byte, NULL);
double geoTransform[6];
_ds->GetGeoTransform(geoTransform);
vrtDS->SetGeoTransform(geoTransform);
GDALSetProjection(vrtDS, _srcProjectionWKT.c_str());
GDALRasterBand* srcBand = _ds->GetRasterBand(1);
vrtDS->AddBand(GDT_Byte, NULL);
VRTSourcedRasterBand* vrtRBand =
(VRTSourcedRasterBand*)vrtDS->GetRasterBand(1);
VRTSourcedRasterBand* vrtGBand =
(VRTSourcedRasterBand*)vrtDS->GetRasterBand(2);
VRTSourcedRasterBand* vrtBBand =
(VRTSourcedRasterBand*)vrtDS->GetRasterBand(3);
vrtRBand->AddComplexSource(srcBand, -1, -1, -1, -1, -1, -1, -1, -1, 0.0,
1.0, VRT_NODATA_UNSET, 1);
vrtGBand->AddComplexSource(srcBand, -1, -1, -1, -1, -1, -1, -1, -1, 0.0,
1.0, VRT_NODATA_UNSET, 2);
vrtBBand->AddComplexSource(srcBand, -1, -1, -1, -1, -1, -1, -1, -1, 0.0,
1.0, VRT_NODATA_UNSET, 3);
Is there anything I have missed in the setup here?
- Thomas
On Tue, Jun 9, 2015 at 1:44 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Thomas,
> > I'm using the GDALWarp api from C++ to reproject and cut various input
> > images. In general this works very well for my purposes, except that for
> > paletted images I have to use NearestNeighbour resampling,
> > I would like to use Bilinear or higher order resampling, and wonder if
> > there is any way to expand a paletted image to true RGB during the warp
> > process, so I can use these resampling methods.
> No, you must use an intermediate step before.
> > Alternatively, is there a way to do this conversion (from code) before
> the
> > warp without having to run through the entire image in memory?
> You can use a in-memory VRT dataset to do on-the-fly expansion to RGB.
> With the AddComplexSource() method of VRTSourcedRasterBand class:
>     CPLErr         AddComplexSource( GDALRasterBand *poSrcBand,
>                                      int nSrcXOff=-1, int nSrcYOff=-1,
>                                      int nSrcXSize=-1, int nSrcYSize=-1,
>                                      int nDstXOff=-1, int nDstYOff=-1,
>                                      int nDstXSize=-1, int nDstYSize=-1,
>                                      double dfScaleOff=0.0,
>                                      double dfScaleRatio=1.0,
>                                      double dfNoDataValue =
> VRT_NODATA_UNSET,
>                                      int nColorTableComponent = 0);
> Set nColorTableComponent to 1,2,3 for respectively R,G,B. This is what
> gdal_translate will do if you use "gdal_translate -of VRT -expand rgb
> pct.tif
> out.vrt"
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150611/ba8c7f03/attachment.html>
