[gdal-dev] is there a vector testfile with Integer64 values?
Roger Bivand Roger.Bivand at nhh.no
Thu Jun 11 22:19:30 PDT 2015
In adapting rgdal for GDAL 2.0.0, it would be useful to know that
clamping, etc, and workarounds for integers in Integer64 fields that
exceed INT_MAX or INT_MIN actually work. Which of the autotest vector
files include Integer64 fields that test reading with Integer or String?
The files I see mostly test error trapping, so an indication of where to
look would be very valuable. Best with common drivers.
Thanks in advance,
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 91 00
e-mail: Roger.Bivand at nhh.no
