[gdal-dev] Files without .dxf extension result invalid
Even Rouault even.rouault at spatialys.com
Fri Jun 12 01:02:57 PDT 2015
Hi Paolo,
> See details at: http://hub.qgis.org/issues/9547
> with sample data.
Yes, the DXF driver currently uses the .dxf extension as the only criterion to
determine if a file is DXF or not.
> Should I open a ticket?
Yes, the driver could possibily be improved to also look at the first lines and
guess if they look like valid DXF. Although it must be extremely uncommon to
have dxf files without .dxf extension.
Even
http://www.spatialys.com
