[gdal-dev] New OGR driver for DB2 Spatial support
Even Rouault even.rouault at spatialys.com
Fri Jun 12 14:50:46 PDT 2015
> > 3. What is the plan for the transition to GDAL 2.0?  My driver was
> > developed against GDAL 1.11.2 and parallels similar drivers for MSSQL,
> > PostGIS, Oracle, etc.
> Current trunk is 2.0,
2.1dev actually ;-)
> with a release candidate out.  You may have to
> do a little work to update the driver.
Should be covered by https://svn.osgeo.org/gdal/trunk/gdal/MIGRATION_GUIDE.TXT
> > This email has been checked for viruses by Avast antivirus software.
> > https://www.avast.com/antivirus
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
