[gdal-dev] Gdal-Grid lidar.
Matt Hanson matt.a.hanson at gmail.com
Mon Jun 15 12:12:54 PDT 2015
Hi Nicolas,
I see someone already posted something about lidar2dems.   We also wanted
to use only open-source, so put together this project to easily be able to
make DEMs using what's out there already.
The documentation gives an overview of what it can do and a tutorial for
processing a large area.
http://applied-geosolutions.github.io/lidar2dems/
I'd like to add multiprocessing support, as it processes in pieces as it
is, so wouldn't take much more work to split it up over processors.
-matt
On Mon, Jun 15, 2015 at 3:00 PM, Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Thanks Even,
> One last question about the buffer. Is 2GB is the max buffer size for
> gdal_grid? If I select that, am I likely to run into problem with some
> values?  Apart from trial and error, is there a balance that should be
> stuck between available computer memory (currently at 64GB), input file
> size and the buffer or can I simply select a 2GB buffer?
> Merci beaucoup pour votre aide.
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> www.archeotec.ca
> On Jun 12, 2015 17:29, Even Rouault <even.rouault at spatialys.com> wrote:
> > Le vendredi 12 juin 2015 23:18:26, Nicolas Cadieux a écrit :
> > > Hi Even,
> > > Thank you very much.  I increased the buffer to 1.5 GB
> > > (512+512+514)*1024*1024 and I can now work much much faster with
> > > gdal_grid.
> > > Does gdal_fillnodata have the same type of variable that could speed
> things
> > > up?  It is also slow and does not seem speeded up by the "All_CPUS".
> > No, no tunable for fillnodata, and it doesn't support multi-threaded
> > parallelization.
> > > I will use warp and the raster calculator in the future so you have
> more
> > > magic up your sleeve, I would appreciate it.
> > > Cheers and thanks again.
> > > www.archeotec.ca
> > > On Jun 5, 2015 19:13, Even Rouault <even.rouault at spatialys.com> wrote:
> > > > Le samedi 06 juin 2015 00:18:45, Nicolas Cadieux a écrit :
> > > > > Hi,
> > > > > I have been using gdal_grid to interpolate LiDAR data for some time
> > > > > now. This would be a typical command:
> > > > > gdal_grid -l P0344_sol2004_XYZI_MTM8_CGVD28_150529 -txe 348733.0
> > > > > 401135.0 -tye 5568587.0 5773796.0 -a
> > > > > nearest:radius1=3.0:radius2=3.0:angle=0.0:nodata=0.0 -outsize
> 52402.0
> > > > > 205209.0 -of GTiff
> > > > > H:/Nicolas/pytemp/OutPut\P0344_sol2004_XYZI_MTM8_CGVD28_150529.vrt
> > > > > H:/Nicolas/pytemp/OutPut\P0344_sol2004_XYZI_MTM8_CGVD28_150529.tif
> > > > > --confi g GDAL_NUM_THREADS ALL_CPUS
> > > > > As you can see, this is a huge raster and the csv. file (Pointed
> with a
> > > > > .vrt) contains over a billion points.  I am trying to do this in
> one
> > > > > shot to avoid boundary effects.  (I know I can split this .csv file
> > > > > into smaller bits and make this more efficient).   The computer I
> am
> > > > > using has 12 cores, 64BG of memory (smaller than the csv file) and
> a
> > > > > 1TB pcie solid state drive.  It should manage the task but it has
> been
> > > > > running for 5 days with less than 10% done).  I have access to a
> super
> > > > > computer with gdal if all else fails.
> > > > > This is my question.  The "--config GDAL_NUM_THREADS ALL_CPUS" or
> > > > > "--config GDAL_NUM_THREADS 12" does not seem to work with the
> nearest
> > > > > neighbor algorithm. (It seem to work with the -a count command)
> If I
> > > > > use this on a smaller data set, I see no difference in speed or cpu
> > > > > usage between using the "ALL_CPUS" or not using this switch.  Is
> this
> > > > > a bug or simply a limitation of the nearest neighbor algorithm?
> > > > Nicolas,
> > > > The threading mechanism is generic for all algorithms . Add "--debug
> on"
> > > > and you should see traces like "GDAL_GRID: Using 12 threads". Now, a
> > > > reason for it not being efficient is that the work buffer used by
> > > > gdalgrid (16 MB) is too small w.r.t to nearest speed. Hum, actually
> > > > looking more closely at the code, I see that the quad tree to index
> the
> > > > points will be rebuilt for each work buffer. This is likely the main
> > > > cause of the inefficiency and why you don't see measurable
> differences
> > > > between non threaded or threaded computations (since the building of
> the
> > > > quadtree is not multithreaded). If you compiled from source, you
> could
> > > > try changing the "const GUInt32 nDesiredBufferSize = 16*1024*1024;"
> line
> > > > in apps/gdal_grid.cpp to a much higher value. A more proper solution
> > > > would be to avoid rebuilding the quad tree for each work buffer.
> This is
> > > > mainly code restructuring.
> > > > An alternative to gdal_grid would be to use gdal_rasterize +
> > > > gdal_fillnodata. This is usually much much faster, so you could try
> to
> > > > check if it gives the results you expect.
> > > > You could also try scipy :
> http://docs.scipy.org/doc/scipy-0.14.0/reference/generated/scipy.interpol
> > > > ate.griddata.html#scipy.interpolate.griddata Not sure how it behaves
> with
> > > > that number of points.
> > > > Even
> > > > > I don't want to move this
> > > > > to a super computer if it will not multi-thread properly.
> > > > > Thanks,
> > > > > Nicolas Cadieux
> > > > > (Gdal1.11.2 downloaded with OSGEO4W 64bit install with QGIS 2.8 on
> > > > > windows 7_64)  I use GDAL from the command line not from QGIS.
> > > > > www.archeotec.ca
> > > > > _______________________________________________
> > > > > gdal-dev mailing list
> > > > > gdal-dev at lists.osgeo.org
> > > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150615/e2a86231/attachment.html>
