[gdal-dev] Question on WFS and encoding
Andreas Neumann a.neumann at carto.net
Thu Jun 18 07:38:49 PDT 2015
Thanks for the temporary workaround - but it is for the server admin to
fix the issue.
Andreas
On 18.06.2015 16:27, Jukka Rahkonen wrote:
> Even Rouault <even.rouault <at> spatialys.com> writes:
>> No easy workaround on OGR side since the OGR GML driver will honour the
> XML encoding indication to do recoding (from what it assumes to be
> ISO-8859-1, but is UTF-8) to UTF-8...
> Hi,
> If you just need the data a non-OGR workaround is to save the GML on disk
> and correct the encoding string by hand or with sed or something.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
