[gdal-dev] Gdal-Grid lidar.
Even Rouault even.rouault at spatialys.com
Thu Jun 18 09:11:20 PDT 2015
Le jeudi 18 juin 2015 17:51:20, Nicolas Cadieux a écrit :
> Thanks,
> That is good news.
> Is the buffer still at 16 mb? If so, why keep it this low?
Choosing a buffer size is always somewhat arbitrary. For example, it might
depend on if people are running only one instance of the utility, or several
at the same time...
> Lidar is very
> demanding even for the best rigs.
With the new changes, I don't think increasing the buffer size should
dramatically change performance, but your experiments will be interesting.
> I will  test out the algorithms and keep you posted on differences between
> nn models.  Will recompile if the buffer is still at 16 mg.  I will also
> look at the new linear interpolation.
> Nicolas
> Nicolas Cadieux M.Sc.
> Les Entreprises Archéotec inc.
> 8548, rue Saint-Denis Montréal H2P 2H2
> Téléphone: 514.381.5112  Fax: 514.381.4995
> www.archeotec.ca
> On Jun 18, 2015 11:43, Even Rouault <even.rouault at spatialys.com> wrote:
> > Le mardi 16 juin 2015 19:00:45, Even Rouault a écrit :
> > > Le mardi 16 juin 2015 18:50:58, Nicolas Cadieux a écrit :
> > > > "As you're exploring new territories, I'd expect you to report how
> > > > this works ;-) "
> > > > Report no 1:
> > > > (Sharing how little I know but still trying to help:)
> > > > I have been recompiling gdal_grid with a 1 and 1.5 GB buffer instead
> > > > of the usual 16 mb.  (Both files created with the 1 and 1.5GB are
> > > > identical).
> > > > Increasing the buffer size makes the interpolation much faster (hour
> > > > instead of weeks) but there may be a possible side effect I would
> > > > like to share.
> > > > It seem that the .tiff file (84GB) is very slow to display in QGIS.
> > > > When I use gdalwarp to resave this file (without actually changing
> > > > the projection or null zero values), I  create an identical file
> > > > with the same dimension and pixel resolution that is blazing fast to
> > > > view in QGIS.  There does not seem to be a pyramid in this new file
> > > > that could explain the results.
> > > > Is it possible that by using such a big buffer, the .tiff is not
> > > > encoded efficiently and that this is fixed when the file is pass
> > > > through gdalwarp?
> > > Ah, no, this is a "well known" behaviour of gdal_grid. It creates an
> > > image whose origin is the bottom-left of the image (instead of the
> > > upper-left usually). Consequently QGIS must creates a warp VRT to get
> > > a more classical dataset, which slow down things.
> > > A trick to generate directly a file with upper-left origin is to
> > > specify "-tye ymax ymin" (instead of "-tye ymin ymax")
> > > I guess this behaviour of gdal_grid should be changed as it regularly
> > > annoys people.
> > Note: I've committed yesterday in gdal trunk 2.1dev several improvements
> > : - the refactorization I mentionned some time ago, to avoid the quad
> > tree to be rebuilt each time, which makes the increasing of the buffer
> > size less necessary - a new algorithm, linear, which is way much much
> > faster than any other existing algorithm and tends to generate better
> > results
> > > > www.archeotec.ca
> > > > On Jun 15, 2015 15:24, Even Rouault <even.rouault at spatialys.com>
wrote:
> > > > > Le lundi 15 juin 2015 21:00:15, Nicolas Cadieux a écrit :
> > > > > > Thanks Even,
> > > > > > One last question about the buffer. Is 2GB is the max buffer size
> > > > > > for gdal_grid? If I select that, am I likely to run into problem
> > > > > > with some values?
> > > > > The variable is a uint32 so you could probably go up to 4 GB.
> > > > > > Apart from trial and error, is there a balance that should be
> > > > > > stuck between available computer memory (currently at 64GB),
> > > > > > input file size and the buffer or can I simply select a 2GB
> > > > > > buffer?
> > > > > this works ;-)
> > > > > > Merci beaucoup pour votre aide.
> > > > > > www.archeotec.ca
> > > > > > On Jun 12, 2015 17:29, Even Rouault <even.rouault at spatialys.com>
> > wrote:
> > > > > > > Le vendredi 12 juin 2015 23:18:26, Nicolas Cadieux a écrit :
> > > > > > > > Hi Even,
> > > > > > > > Thank you very much.  I increased the buffer to 1.5 GB
> > > > > > > > (512+512+514)*1024*1024 and I can now work much much faster
> > > > > > > > with gdal_grid.
> > > > > > > > Does gdal_fillnodata have the same type of variable that
> > > > > > > > could speed things up?  It is also slow and does not seem
> > > > > > > > speeded up by the "All_CPUS".
> > > > > > > No, no tunable for fillnodata, and it doesn't support
> > > > > > > multi-threaded parallelization.
> > > > > > > > I will use warp and the raster calculator in the future so
> > > > > > > > you have more magic up your sleeve, I would appreciate it.
> > > > > > > > Cheers and thanks again.
> > > > > > > > www.archeotec.ca
> > > > > > > > On Jun 5, 2015 19:13, Even Rouault
> > > wrote:
> > > > > > > > > Le samedi 06 juin 2015 00:18:45, Nicolas Cadieux a écrit :
> > > > > > > > > > Hi,
> > > > > > > > > > I have been using gdal_grid to interpolate LiDAR data for
> > > > > > > > > > some time now. This would be a typical command:
> > > > > > > > > > gdal_grid -l P0344_sol2004_XYZI_MTM8_CGVD28_150529 -txe
> > > > > > > > > > 348733.0 401135.0 -tye 5568587.0 5773796.0 -a
> > > > > > > > > > nearest:radius1=3.0:radius2=3.0:angle=0.0:nodata=0.0
> > > > > > > > > > -outsize 52402.0 205209.0 -of GTiff
> > > > > > > > > > H:/Nicolas/pytemp/OutPut\P0344_sol2004_XYZI_MTM8_CGVD28_1
> > > > > > > > > > 5052 9. vrt
> > > > > > > > > > 5052 9 .tif --confi g GDAL_NUM_THREADS ALL_CPUS
> > > > > > > > > > As you can see, this is a huge raster and the csv. file
> > > > > > > > > > (Pointed with a .vrt) contains over a billion points.  I
> > > > > > > > > > am trying to do this in one shot to avoid boundary
> > > > > > > > > > effects.  (I know I can split this .csv file into
> > > > > > > > > > smaller bits and make this more efficient). The computer
> > > > > > > > > > I am using has 12 cores, 64BG of memory (smaller than
> > > > > > > > > > the csv file) and a 1TB pcie solid state drive.  It
> > > > > > > > > > should manage the task but it has been running for 5
> > > > > > > > > > days with less than 10% done).  I have access to a super
> > > > > > > > > > computer with gdal if all else fails.
> > > > > > > > > > This is my question.  The "--config GDAL_NUM_THREADS
> > > > > > > > > > ALL_CPUS" or "--config GDAL_NUM_THREADS 12" does not seem
> > > > > > > > > > to work with the nearest neighbor algorithm. (It seem to
> > > > > > > > > > work with the -a count command)  If I use this on a
> > > > > > > > > > smaller data set, I see no difference in speed or cpu
> > > > > > > > > > usage between using the "ALL_CPUS" or not using this
> > > > > > > > > > switch.  Is this a bug or simply a limitation of the
> > > > > > > > > > nearest neighbor algorithm?
> > > > > > > > > Nicolas,
> > > > > > > > > The threading mechanism is generic for all algorithms . Add
> > > > > > > > > "--debug on" and you should see traces like "GDAL_GRID:
> > > > > > > > > Using 12 threads". Now, a reason for it not being
> > > > > > > > > efficient is that the work buffer used by gdalgrid (16 MB)
> > > > > > > > > is too small w.r.t to nearest speed. Hum, actually looking
> > > > > > > > > more closely at the code, I see that the quad tree to
> > > > > > > > > index the points will be rebuilt for each work buffer.
> > > > > > > > > This is likely the main cause of the inefficiency and why
> > > > > > > > > you don't see measurable differences between non threaded
> > > > > > > > > or threaded computations (since the building of the
> > > > > > > > > quadtree is not multithreaded). If you compiled from
> > > > > > > > > source, you could try changing the "const GUInt32
> > > > > > > > > nDesiredBufferSize = 16*1024*1024;" line in
> > > > > > > > > apps/gdal_grid.cpp to a much higher value. A more proper
> > > > > > > > > solution would be to avoid rebuilding the quad tree for
> > > > > > > > > each work buffer. This is mainly code restructuring.
> > > > > > > > > An alternative to gdal_grid would be to use gdal_rasterize
> > > > > > > > > + gdal_fillnodata. This is usually much much faster, so
> > > > > > > > > you could try to check if it gives the results you expect.
> > > > > > > > > You could also try scipy :
> > > > > > > > > http://docs.scipy.org/doc/scipy-0.14.0/reference/generated/
> > > > > > > > > scip y. inte rpol
> > > > > > > > > ate.griddata.html#scipy.interpolate.griddata Not sure how
> > > > > > > > > it behaves with that number of points.
> > > > > > > > > Even
> > > > > > > > > > I don't want to move this
> > > > > > > > > > to a super computer if it will not multi-thread properly.
> > > > > > > > > > Thanks,
> > > > > > > > > > Nicolas Cadieux
> > > > > > > > > > (Gdal1.11.2 downloaded with OSGEO4W 64bit install with
> > > > > > > > > > QGIS 2.8 on windows 7_64)  I use GDAL from the command
> > > > > > > > > > line not from QGIS.
> > > > > > > > > > www.archeotec.ca
> > > > > > > > > > _______________________________________________
> > > > > > > > > > gdal-dev mailing list
> > > > > > > > > > gdal-dev at lists.osgeo.org
> > > > > > > > > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
