[gdal-dev] Getting warning when opening NetCDF file using gdal?
Anton Korosov anton.korosov at nersc.no
Tue Jun 30 00:40:52 PDT 2015
Hi!
The format of the new OBPG OceanColor files is HDF5 (aka NetCDF4), so
you should have your GDAL compiled with HDF5 support:
http://www.gdal.org/frmt_hdf5.html
Then you can access the content of the file using groups and variables
syntax:
gdalinfo HDF5:"A2015069035500.L2_LAC_OC.nc"://geophysical_data/chlor_a
Regards!
Anton
On 30/06/15 04:48, oz wrote:
> I am using windows 7(32-bit) and want to warp NetCDF (nc) files and save the
> output as GeoTIFF.
> First I run gdalinfo first to get the info of the subdataset I need and
> added NeTCDF in the beginning(e.g. gdalinfo
> NETCDF:"A2015069035500.L2_LAC_OC.nc") but was unfortunate because a warning
> appeared:
> Warning 1: Variable has 0 dimension(s) - not supported.
> gdalinfo failed - unable to open 'netCDF:A2015069035500.L2_LAC_OC.nc'.
> Command line input:
> gdalinfo A2015069035500.L2_LAC_OC.nc
> NetCDF is present when I tried `gdalinfo --formats`.
> Does anyone have any idea about this?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Getting-warning-when-opening-NetCDF-file-using-gdal-tp5213484.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
