[gdal-dev] Driver oddity
Ari Jolma ari.jolma at gmail.com
Sat Mar 7 05:09:28 PST 2015
The GDAL and OGR drivers are now basically the same but separate ones in
Swig bindings, maybe it has something to do with this oddity.
When I open GDAL driver "Memory", it does not advertise capability
DCAP_RASTER and CreateDataset silently fails.
When I open GDAL driver "MEM", it advertises capability DCAP_RASTER and
CreateDataset returns a valid object.
When I open MEM driver and then Memory driver, both behave similarly.
Both MEM and Memory are listed as GDAL drivers.
Cheers,
Ari
first run:
perl x.pl Memory
DCAP_CREATE => YES
DCAP_OPEN => YES
DCAP_VECTOR => YES
DMD_CREATIONFIELDDATATYPES => Integer Integer64 Real String Date
DateTime Time IntegerList Integer64List RealList StringList Binary
DMD_LONGNAME => Memory
OGR_DRIVER => YES
DCAP_CREATE => YES
DCAP_OPEN => YES
DCAP_VECTOR => YES
OGR_DRIVER => YES
second run:
perl x.pl MEM
DCAP_CREATE => YES
DCAP_OPEN => YES
DCAP_RASTER => YES
DMD_CREATIONDATATYPES => Byte Int16 UInt16 Int32 UInt32 Float32 Float64
CInt16 CInt32 CFloat32 CFloat64
DMD_CREATIONOPTIONLIST => <CreationOptionList>   <Option
name='INTERLEAVE' type='string-select' default='BAND'>
<Value>BAND</Value> <Value>PIXEL</Value> </Option></CreationOptionList>
DMD_LONGNAME => In Memory Raster
Geo::GDAL::Dataset=HASH(0xd020a0)
DCAP_CREATE => YES
DCAP_OPEN => YES
DCAP_RASTER => YES
Geo::GDAL::Dataset=HASH(0xd77df0)
the program:
use Geo::GDAL;
$driver = shift @ARGV;
$d = Geo::GDAL::Driver($driver);
$m = $d->GetMetadata;
for my $k (sort keys %$m) {
     print "$k => $m->{$k}\n";
$s = $d->Create();
print $s,"\n";
print "\n";
$d = Geo::GDAL::Driver('Memory');
$s = $d->Create();
print $s,"\n";
