[gdal-dev] Download GDAL 2.0 - gdal_translate -tx
Zoltan Szecsei zoltans at geograph.co.za
Sun Mar 8 07:17:27 PDT 2015
On 03/08/2015 04:15 PM, Even Rouault wrote:
> Le dimanche 08 mars 2015 15:10:42, Zoltan Szecsei a écrit :
>> On 03/08/2015 01:57 PM, Even Rouault wrote:
>>> Le dimanche 08 mars 2015 12:46:34, Zoltan Szecsei a écrit :
>>>> On 03/08/2015 01:43 PM, Even Rouault wrote:
>>>>> Le dimanche 08 mars 2015 12:39:03, Zoltan Szecsei a écrit :
>>>>>> Hi,
>>>>>> I'd like to install gdal v2.0 but cannot seem to find it.
>>>>>> I'm using Ubuntu 14.10
>>>>>> uname -a
>>>>>> Linux gs01 3.16.0-31-generic #41-Ubuntu SMP Tue Feb 10 15:24:04 UTC
>>>>>> 2015 x86_64 x86_64 x86_64 GNU/Linux
>>>>>> gdal_translate --version
>>>>>> GDAL 1.11.1, released 2014/09/24
>>>>> Zoltan,
>>>>> 2.0 is still in development. You have to download it from sources.
>>>> OK - svn checkout gdal-trunk?
>>> See
>>> http://trac.osgeo.org/gdal/wiki/DownloadSource#Developmentversionandsourc
>>> econtrol
>> Hi,
>> I've just successfully downloaded, compiled & installed the trunk version:
>> GDAL 2.0.0dev, released 2014/04/16
>> yet I still don't have access to the '-tx' parameter for gdal_translate:
> I guess you meant -tr
It says:
> *-tr*xres yres :
>     (starting with GDAL 2.0) set target resolution. The values must be
>     expressed in georeferenced units. Both must be positive values.
>     This is exclusive with -outsize and -a_ullr.
>> gdal_translate -tx $r $r -projwin $w $n $e $s $img ${AW}${i}.tif
>> FAILURE: Unknown option name '-tx'
>> Are the help-docs at http://www.gdal.org/gdal_translate.html just ahead
>> of the source, or did I miss something?
>> Regards,
>> Zoltan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150308/cac69fa7/attachment.html>
