[gdal-dev] Bindings and typemaps
Ari Jolma ari.jolma at gmail.com
Mon Mar 9 06:47:48 PDT 2015
I'm curious about the setup.
Do you commit to github, which then commits to trac.osgeo.org/gdal or
how is the system setup?
Ari
09.03.2015, 15:31, Even Rouault kirjoitti:
> Le lundi 09 mars 2015 14:27:05, Ari Jolma a écrit :
>> 09.03.2015, 11:18, Even Rouault kirjoitti:
>>> Or if you prefer Git, you could fork https://github.com/OSGeo/gdal
>> I did this fork and made the changes in my copy. Then made a pull
>> request and now it says that the Travis CI build passed.
>> But I assume Java etc. are not tested by Travis?
> The Java, Perl and Python bindings are tested by Travis. See .travis.yml at
> the root of the repository
> I've just added in Vagrant the ability to build the Java and CSharp bindings,
> as well as Perl and Python. It turns out that Swig 2.0.4 that comes with
> Ubuntu 12.04 isn't compatible with the CSharp bindings. So the .cpp files are
> generated by a manually compiled swig 1.3.40. But at runtime I get a linking
> failure.
>> Ari
