[gdal-dev] OpenFileGDB, feature classes in feature dataset
Even Rouault even.rouault at spatialys.com
Mon Mar 9 22:48:12 PDT 2015
Selon Armin Burger <armin.burger at gmx.net>:
> Dear all
> I have a question regarding the OpenFileGDB driver in 1.11.2 release. It
> now lists also non-spatial tables as layers of an FGDB (as mentioned in
> the changelog). But it seems to not list any more layers that are
> "feature classes" under a parent "feature dataset" (that's how the
> relation is displayed in ArcGIS). This is at least the case for FGDB's
> in older v9 format. In GDAL version 1.11.0 these feature classes were
> still listed as layers.
> Is this a bug or an intended behavior?
Looks like an unfortunate side effect. could you open a ticket and attach such a
GDB or provide a link to it ?
> Best regards
> Armin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
