[gdal-dev] GNM Usage
Dmitriy Baryshnikov bishop.dev at gmail.com
Wed Mar 11 06:15:31 PDT 2015
I also would like to note, that this is the simple and sample algorithm.
You free to use the GNM API to create more complex connections. For
example, the GNM allows to connect some polygons (i.e. countries)
without physical  geometry intersect/connect (logical connection). So,
you have more capabilities, but (by now) using API of GNM.
Best regards,
     Dmitry
11.03.2015 15:01, ChiefDan пишет:
> Thanks for the info!
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GNM-Usage-tp5192401p5192776.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
