[gdal-dev] Shapefile driver and support for Boolean attributes
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Wed Mar 18 14:02:07 PDT 2015
Is there some special reason why the shapefile driver does not support
Logical (Boolean) data type for attributes? It seems that the "L" data type
is there in dBase III format
https://ulisse.elettra.trieste.it/services/doc/dbase/DBFstruct.htm#C1.4 and
even well defined Value: "? Y y N n T t F f (? when not initialized)".
-Jukka Rahkonen-
