[gdal-dev] Ruby bindings
Ari Jolma ari.jolma at gmail.com
Wed Mar 18 20:21:55 PDT 2015
19.03.2015, 05:55, Even Rouault kirjoitti:
> Hi,
> The build of Ruby bindings is broken in trunk. See
> http://trac.osgeo.org/gdal/ticket/5880
> The situation is that, in years, nobody has really maintained them, so it isn't
> even sure that they work at runtime once compilation issues are fixed. So we
> might just have to wipe them out, or remove them from configure, if nobody steps
> up to maintain them. Opinions ?
IMO, remove from configure. Or, at least make it non-automatic.
I would have thought the cause was me since I did some changes in the
common include files but that does not seem to be the case. For some
reason ogr_error_map.i is not included when making gdal_wrap.cpp. It
should be since it is in the ruby typemaps??
Ari
> Even
