[gdal-dev] ogr2ogr: Stuck trying to append lots of gml files to postgis tables
Even Rouault even.rouault at spatialys.com
Sun Mar 22 12:32:32 PDT 2015
Le dimanche 22 mars 2015 20:18:12, Stephen Woodbridge a écrit :
> Hi all,
> I have a directory of gml files. I can load any of them into postgis
> without a problem. What I'm having a problem with is appending each file
> to the existing tables. I'm using : GDAL 1.10.1, released 2013/08/26
> $ ogrinfo raw_itn/6360199_sn6103_2c7157.gz
> Had to open data source read-only.
> INFO: Open of `raw_itn/6360199_sn6103_2c7157.gz'
>        using driver `GML' successful.
> 1: Road (None)
> 2: RoadLink (Line String)
> 3: RoadNode (Point)
> $ ogrinfo raw_itn/6360199_sn6101_2c5532.gz
> INFO: Open of `raw_itn/6360199_sn6101_2c5532.gz'
> 1: RoadLinkInformation (Point)
> 2: Road (None)
> 3: RoadLink (Line String)
> 4: RoadNodeInformation (None)
> 5: RoadNode (Point)
> Here is want I am trying:
> dropdb -U postgres -h localhost data_itn
> createdb -U postgres -h localhost data_itn
> psql -U postgres -h localhost data_itn -c "create extension postgis"
> psql -U postgres -h localhost data_itn -c "create schema itn"
> psql -U postgres -h localhost data_itn -c "alter database data_itn set
> search_path to itn, public, pg_catalog"
> # this loads fine
> ogr2ogr -append -f PostgreSQL PG:"host=localhost user=postgres
> dbname=data_itn" raw_itn/6360199_sn6101_2c5532.gz
> # all successive tries to append to the existing tables fails
> dbname=data_itn" raw_itn/6360199_sn6103_2c7157.gz
> ERROR 1: Layer road already exists, CreateLayer failed.
> Use the layer creation option OVERWRITE=YES to replace it.
> ERROR 1: Terminating translation prematurely after failed
> translation of layer Road (use -skipfailures to skip errors)
> If I don't install extension postgis then there is no problem reported
> and it appears to load all the data by appending the tables with the
> geometry in a colum wkb_geometry::bytea.
> How can I load the data into postgis. I have over 700 gml files to load.
Defining PG_LIST_ALL_TABLES=YES as environment variable should solve this. By
default non-spatial tables are not listed when opening a PG database, and
ogr2ogr is confused as it doesn't see the existing table as existing, so it
tries to recreate it. With trunk, ogr2ogr & the PG driver have been improved
so that specifying  PG_LIST_ALL_TABLES=YES is not needed in that scenario.
Wondering if we shouldn't list all tables (excluding system tables) by
default...
> Thanks,
>    -Steve
> This email has been checked for viruses by Avast antivirus software.
> http://www.avast.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
