[gdal-dev] Issues configurign PostGIS with GDAL 1.11.2
Stefano Iacovella stefano.iacovella at gmail.com
Wed Mar 25 05:37:19 PDT 2015
May be I have found a clue about the issue.
Looking at the config.log I have found these rows:
| #define HAVE_GDAL_H 1
| #define HAVE_OGR_API_H 1
| #define HAVE_CPL_CONV_H 1
| /* end confdefs.h.  */
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char GDALAllRegister ();
| int
| main ()
| return GDALAllRegister ();
|   return 0;
configure:20670: gcc -o conftest  -I/usr/local/include  conftest.c -lgdal
-L/usr/local/lib -lgdal >&5
//home/stefano/arcsdetools/sdeexe102/lib/libsde.so: undefined reference to
`pthread_atfork'
collect2: error: ld returned 1 exit status
configure:20670: $? = 1
could this error be the cause of the previous one?
I can't remember exactly when I installed the ArcSDE SDK and then
recompiled GDAL but I am pretty sure it was after compiling PostGIS 2.1.5
Thanks again
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2015-03-25 12:51 GMT+01:00 Stefano Iacovella <stefano.iacovella at gmail.com>:
> Hi all,
> sorry for the cross-posting, I am not sure whether the issue is more
> relevant to GDAL or PostGIS.
> I tried to compile PostGIS 2.1.6 on my Linux Box but the first step end
> with an error:
> ~/sources/postgis-2.1.6 $ ./configure --with-gui
> TOPOLOGY: Topology support requested
> RASTER: Raster support requested
> checking for gdal-config... /usr/local/bin/gdal-config
> checking GDAL version... 1.11.2
> checking for OGR enabled... yes
> checking gdal.h usability... yes
> checking gdal.h presence... yes
> checking for gdal.h... yes
> checking ogr_api.h usability... yes
> checking ogr_api.h presence... yes
> checking for ogr_api.h... yes
> checking cpl_conv.h usability... yes
> checking cpl_conv.h presence... yes
> checking for cpl_conv.h... yes
> checking for library containing GDALAllRegister... no
> configure: error: could not find GDAL
> It is the same Linux Box, Mint 17, on which I had previously successfully
> configured and compiled PostGIS 2.1.5 on GDAL 1.11.1
> The upgrade to GDAL 1.11.2 was done after the compilation of PostGIS 2.1.5
> so I guess the problem may be related to this release.
> I have in fact also tried to use the same configure command on sources for
> PostGIS 2.1.5 but got the same error.
> Am I doing something wrong or is it a bug?
> Thank you in advance for your help
> Stefano
> 41.95581N 12.52854E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150325/d7671aeb/attachment.html>
