[gdal-dev] GSOC 2015 proposal - Integration of cpp GDAL utilities into GDAL core library
Daniel Morissette dmorissette at mapgears.com
Fri Mar 27 13:15:28 PDT 2015
+1 to Even's explanation on why this would be a very welcome addition.
We should also add to the requirements a refactoring of the "complex
code" to  structure the messages/information that is currently output to
stdout by the command-line utilities so that the calling program can
interpret and present that info to the end user in a meaningful way.
Daniel
On 2015-03-27 4:08 PM, Even Rouault wrote:
> Peter,
>> Maybe I've missed the point (through over familiarity with GDAL/OGR?)
>> .... but these utilities were originally branded as 'worked examples'
>> of how to use the substantive libraries to perform well understood
>> operations from which usage of the libraries might be readily
>> understood.  Each utility is itself a commented set of function calls
>> to the relevent GDAL libraries.
> There is non trivial logic involved in some of the utilities (e.g. ogr2ogr)
> and people have the choice between :
> - doing a system call ("ogr2ogr ...."), but this isn't practical to deal with
> progress report, cancellation, or operating on in-memory datasets
> - copy&pasting the source code of the utility in their own code, and
> "librarify'ing" it to remove exit(), etc...
> - learning the GDAL/OGR API to do their own custom processing chain. More
> powerfull but longer learning curve
> So the interest of the project would be to make life easier for people using
> the first 2 bullets (and I can tell you that there are a lot of people hitting
> those 2 bullets)
>> Why is there a need to duplicate this
>> in turning the utilities into function calls which then, in turn, must
>> be called by new stand-alone utilities?
>> There has to be a loss of
>> efficiency in sunch a process.
> I don't think there will be a loss of efficiency
> Instead of ogr2ogr.cpp being currently
> int main(...)
> 	complex_code
> you would have (very schematically)
> ogr2ogr.cpp:
> int main(...)
>         ogr2ogr_options = parse aguments()
>         return ogr2ogr(ogr2ogr_options)
> and libgdalutils_ogr2ogr.cpp :
> int ogr2ogr(ogr2ogr_options)
>       complex_code (moved from currently existing main)
> Even
Daniel Morissette
T: +1 418-696-5056 #201
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
