[gdal-dev] gdal jar in maven central
Even Rouault even.rouault at spatialys.com
Tue Mar 31 09:41:07 PDT 2015
Le mardi 31 mars 2015 18:29:18, Justin Deoliveira a écrit :
> On Tue, Mar 31, 2015 at 10:01 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > > Right, there are a few steps involved. The easiest vector that I have
> > seen
> > > for open source projects  is to utilize the Sonatype OSSRH repositories
> > > (which provide sync to maven central). The full process is described
> > here.
> > >   http://central.sonatype.org/pages/ossrh-guide.html#review-requirement
> > >   s
> > > To sum it up though, here is what I think would be required for gdal.
> > > 1. Create a pom for the gdal jar that adheres to these requirements:
> > > http://central.sonatype.org/pages/requirements.html#sufficient-metadata
> > > 2. Have a developer set up an OSSRH account and do the initial setup.
> > >      http://central.sonatype.org/pages/ossrh-guide.html#initial-setup
> > > 3. For each release build the gdal jar (along with it's source and
> > javadoc
> > > artifacts) and GPG sign them.
> > http://central.sonatype.org/pages/requirements.html#sign-files-with-gpgpg
> > p
> > >    Then deploy all the jars/signatures to the OSSRH staging
> > >    repositories.
> > > This will eventually sync them to maven central.
> > > Again I'm happy to volunteer to do these steps if there aren't any
> > > developers on the project that want the extra hassle. Do the java
> > bindings
> > > have a dedicated maintainer at this point?
> > I've somehow taken that hat on, but I've currently no real incentive to
> > do work in the Java area, so I'm happy if you want to take care of that
> > aspect.
> > Beyond the initial setup, it would be great if the steps that need to be
> > taken
> > at each release are documented in our HOWTO-RELEASE document (at the root
> > of
> > the source tree) so that anyone not familiar with Java/maven/Sonatype
> > OSSRH can follow the steps in a rather brainless mode.
> > Sure thing. I haven't done much with swig or anything aside from
> > compiling
> the bindings, but happy to learn as tasks come up.
> So how about for a start I work toward deploying the latest stable release
> (1.11.2) jar into maven central. As part of that process I'll document the
> steps required and prepare a patch for HOWTO-RELEASE. Will that work?
Sounds good.
> > > > > > Regards,
> > > > > > Even
> > > > > > Spatialys - Geospatial professional services
> > > > > > http://www.spatialys.com
