[gdal-dev] define netcdf time dimension
Etienne Tourigny etourigny.dev at gmail.com
Fri May 1 03:57:11 PDT 2015
GDAL cannot be used to manipulate the netcdf dimension definitions.
You should use something specialized in dealing with netcdf dimensions such
as cdo [1] or nco [2].
[1] https://code.zmaw.de/projects/cdo
[2] http://nco.sourceforge.net/
On Tue, Apr 14, 2015 at 2:46 AM, Dominik Schneider <
Dominik.Schneider at colorado.edu> wrote:
> Hi -
> I have some .mdl files from IDL with .hdr header files that I’d like to
> convert to netcdf.
> The following code produces a netcdf file with a subdataset for each band
> in the mdl file. Is there any way to define the bands as the time
> dimension, in this case 4416 hourly timesteps?
> Or is there another tool that can convert this?
> gdal_translate -of NetCDF swe.mdl swe.nc
> Thanks
> Dominik​
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150501/36a3e26d/attachment.html>
