[gdal-dev] GDAL 2.0 release plans
Even Rouault even.rouault at spatialys.com
Sun May 3 04:09:46 PDT 2015
> It's strange as I create patch with same command (svn diff --force >
> ~/md_reader.patch) as previous one.
I didn't try to apply during my first review. Just looked at the diff.
> I add changes for metadata readers directly to svn trunk copy on my PC.
> I can create pull request for github GDAL trunk, but it takes some time
> to do, or I can just commit to svn trunk (preferable).
> If something will be wrong, it can be easily roll back.
> So, I decide to commit my changes to trunk.
Sounds good. Once it is applied, you can have a look at the different test
platforms (builds are scheduled at most 15 minutes after commit) :
https://travis-ci.org/rouault/gdal_coverage/builds/
> Best regards,
>      Dmitry
> 03.05.2015 12:11, Even Rouault пишет:
> > Dmitry,
> > I didn't manage to apply the patch (due to the binary files)
> > $ patch -p0 < /tmp/md_reader.patch
> > patching file autotest/gcore/data/md_dg.IMD
> > patching file autotest/gcore/data/md_dg.RPB
> > patching file autotest/gcore/data/md_dg.tif
> > patch: **** malformed patch at line 187: \ No newline at end of file
> > Is there some branch somewhere where it can be tested ?
> > That said, I have no further remarks on this updated patch which looks
> > good to me.
> > Even
> > Le dimanche 03 mai 2015 01:34:04, Dmitry Baryshnikov a écrit :
> >> Hi everybody,
> >> Let me introduce the patch to the current GDAL v.2 trunk. This patch
> >> change the way how imagery (satellite or aerial) metadata read. I create
> >> some base classes and several metadata readers: DigitalGlobe, GeoEye,
> >> OrbView (change existed code to use metadata readers), add Landsat,
> >> Pleiades, Resurs-DK1 (plan to add about 6 new satellites). Also I added
> >> new metadata domain: IMAGERY to hold some common imagery metadata:
> >> satellite, cloud cover, acquisition date/time. The cloud cover transform
> >> to values from 0 to 100 or 999 for n/a, and date/time to UTC.
> >> Additional code review and testing are welcome. Also let me know, if I
> >> can commit this changes to trunk.
> >> P.S. Even review the code of previous patch. I fix all errors reported
> >> by Even.
> >> Best regards,
> >>       Dmitry
> >> 29.04.2015 21:40, Even Rouault пишет:
> >>> Hi,
> >>> I wanted to have an update from other developers to know where there
> >>> are with respect to their planned schedule.
> >>> I had noted that :
> >>> - Dmitriy wanted to integrate his work on metadata support for various
> >>> satellite imagery. I have reviewed a preliminary version of it.
> >>> - Ari has ongoing work on Perl. I've seen a few commits passed.
> >>> - Pirmin intended to add curve support in Interlis. Haven't seen yet
> >>> any commit.
> >>> Are you still in track to finalize those works in the following days ?
> >>> Would adding the week-end help to have that in Beta1 ? I especially
> >>> think to Dmitriy's work who is quite substantial, and perhaps Perl
> >>> changes if there are still breaking change to come. Interlis specfic
> >>> changes might arrive after Beta1 I think.
> >>> Even
> >>>> Hi,
> >>>> Some time ago, I mentionned my proposal of issuing a first GDAL 2.0
> >>>> beta version for the end of this month (April 30th). Are there
> >>>> objections to sticking with that plan ? Does someone need a bit more
> >>>> time to finish an ongoing work ?
> >>>> And if things go well with this beta (and potentially other beta(s)
> >>>> needed), we could try a release candidate for end of May. One month of
> >>>> beta phase might seem a bit short, but I'm not sure extending the beta
> >>>> testing period more will bring significant additional feedback (and
> >>>> things tend to slip, so better aim for a tight schedule). Thoughts ?
> >>>> Anyone using GDAL intensively and/or interesting in 2.0 should already
> >>>> track trunk closely ;-)
> >>>> I can wear the hat of 2.0 release manager, but I'm happy to let it to
> >>>> any other volunteer.
> >>>> Best regards,
> >>>> Even
http://www.spatialys.com
