[gdal-dev] Problems with MySQL queries in GDAL
Pavol Hnila pavol.hnila at fu-berlin.de
Thu May 7 05:29:31 PDT 2015
> Note that you can specify a tables=a_table;another_table option in the mysql
> connection string that will restrict the number of tables visible&queried to
> the ones you specify
Works like charm for the performance... This might be the solution, if
implemented in QGIS. I will present the topic in the QGIS-developer
mailing list.
Many thanks Even,
Pavol
